Carwyn
  • Content count
    75
Everything posted by Carwyn
  1. Carwyn
    Building own fixture
    All done now mate werent looking at the fixture editor properly
  2. Carwyn
    Hi Guys and Gals I Need to build a fixture up, it is basically led tape which I've installed on the steps at the venue. controlls need to be RGB and intensity the controller is a 3 channel controller so how would i get the intensity to control the whole unit then HELP
  3. Hi guys Mid show without anyone touching it my lepfrog decides to do random reboots its now done about 6 reboots in about 20 mins power in the building is steady powers plugged in ok. Any ideas
  4. Carwyn
    ETC Coloursource file fixture
    Thanks for this
  5. Hi All Has anyone go a fixture file for a ETC colour source par and profile. Thanks Carwyn
  6. Hi Has anyone got the fixture file for a Equinox PARTY PAR Thanks Carwyn
  7. Carwyn
    Desk randomly rebooting
    7.8 or 7.8.2
  8. Carwyn
    2 universes, power supply, and a usb stick thats been working fine with the desk for months. Desk has been turned on since 10am this morning been fine all day and between 8.35 and 9.05 this evening rebooted 7 times and there was nobody next to it it stabalised for 10 mins so after that hard power down and power up then been stable rest of the evening for at least an hour
  9. Carwyn
    Midi cue's via network
    Hi Can the leapfrog take midi cue's from the network? What is the midi cue for hitting the go button? Thank You Carwyn
  10. Carwyn
    inhibbit
    Thanks for the reply but would be nice to have this function i know about the topset function but working on a fiew shows where this function would be handy
  11. Carwyn
    inhibbit
    Is there a way to do an inhibbit channel on the leapfrog it would be great if it could do it with the subs.
  12. Carwyn
    Hi guys thanks for the replies just wondering if i could trigger the go button via a midi input from a sound desk able to output midi codes. What is the midi code to trigger the go button?
  13. Hi All This may seem a idiotic question but how do you patch channels 97 - 99 on the desk as when your in patch or patch edit you are unable to select them unless im compleately blind. ive been using this desk for some 7 years now and its now doing my head in. theyre visible on the outputs screen but never been able to patch to them Thank You Carwyn
  14. Carwyn
    showtec indigo 5500
    Hi jon Thanks for that. The joys of getting movers in last minuit and going straight into a plotting session. Yip i was the guy that phoned also
  15. Carwyn
    showtec indigo 5500
    has anyone got a personality for a showtec indigo 5500
  16. Hi Is there a command to change the submaster page from page 15 to page 1 in syntax. For Example 'Submaster Page 1' or 'Submaster Page 10' Thank You Carwyn
  17. Carwyn
    Easier Patching Method
    Hi Is there a easier way to patch rather tHan making your way through the table as in, go into patch then allow you to patch on the external keyboard as in the following format- Channel number * dmx* dmx enter 1*5*7 enter 2*6*8 enter Thanks in advance
  18. Carwyn
    Remote Software
    Hi Can anyone point me in the direction of the remote software for my computer to run my desk with please Thanks Carwyn
  19. hi just noticed that the backspace button on the mfk's dont work is there another way round this without using the keyboard Thanks Carwyn
  20. Carwyn
    next dimmer function
    thank you for the information jon
  21. Carwyn
    is there a way if ive done on my i pod touch via comand line 1>full then is there a way of doing a next button so that 1 goes off and 2 comes on and so on and so fourth. maybee if youve got a channel on like that the + and minus can the change to the next and - changes to previous
  22. Carwyn
    EDIT: profanity removed
  23. is there a way if i had my laptop plugged in as a remote to view one set of images on one screen and different set of images on the other screen if you know what i mean thank You Carwyn
  24. Carwyn
    command over art net
    HI could anyone tell me what the trigger comand would be for 1. triger the go button over art net or go to q? 2 submaster 1 up or 1 down if this is possible
