Studio Tech
  • Content count
  1. Speeds Of Chases On Subs - Individual Adjustment
    Thanks Edward, It's the second method I had been trying to use, but I couldn't see how to actually select individual sub-masters - a bit of experimentation has now revealed that I should've been using [SHIFT+FLASH BUTTON] to make the selection. E2A So the behavior I get now is (1) run a number of chases (2) select sub whose speed I want to change (using [SHIFT+FLASH BUTTON] to make the selection) (3) hold [SHIFT] and adjust the speed control and the speed of the selected chase only changes but only until I release the shift key, then all of the running chases change to the new speed.
  2. Sorry if this has been asked before, but I can't seem to find the an answer to this one. I have the desk in 'Run' mode and have chases programmed to several subs. At the moment, the 'Speed' control seems to be a global speed adjustment for all chases, but what I would like to be able to do is to individually adjust the speed of chases whilst still in 'Run' mode. Is this possible? Thanks in advance.
