Edward- Z88
Zero 88
  • Content count
Everything posted by Edward- Z88
  1. Showtec Shark Wash One
    Hi Kevin, Thanks very much for that, will ensure it is included in Fixture Library 36. Edward
  2. Advice - S24
    Thanks very much for the excellent review! And don’t forget the FLX S48 doubles the Fixture count, number of Playbacks, Groups and Palettes to 96 of each. Edward
  3. Fixture Needed (Chauvet Rogue R2 Wash)
    Hi Shane, This fixture is included in the latest fixture library, available to download here... http://zero88.com/forum/files/file/8-fixture-library-full/ However if you don't wish to update their fixture library, please find the individual requested fixture for you to load in... Chauvet Rogue R2 Wash.ift Any queries let me know. Edward
  4. Submaster controlling the dimmer channel??
    Hi Carpo, The quickest way to record your Fixture groups to a Playback fader, is to double tap the group you want so the fixtures come to full, tap RECORD, and tap the flashing Playback button you want their intensity stored to. If you need more programming tips, feel free to email me directly and we can talk through what you’re after. Edward
  5. Submaster controlling the dimmer channel??
    Hi Carpo, Could you expand on this a little? Have you got one Playback with an intensity effect and one with a intensity chase? If so intensity on Playbacks will always mix together HTP (Highest intensity value takes precedence). Intensity from Channel faders is a little different, as it has highest priority, which is why the CLEAR button lights to allow you to clear these Red values, and allow your Playbacks to take control. Edward
  6. Effect Chaser with Sunstrip 10ch
    Hi Fred, No update on this one yet I’m afraid. We’ve been working on ZerOS 7.9.4, which is an enhancement/ bug fix software update due to be released within the next week. Your best bet is to plan your rig allowing for each segment of the sun strip to be an individual fixture. Any queries let me know Edward
  7. ML Position move time
    Hi James, There is no Real-Time Clock on FLX S consoles. The Time displayed when the console is locked is the run time, which is fixed in the latest software. Any queries let me know Edward
  8. ML Position move time
    Hi James, Looking at your show file, you have "Fader Controls... Colour, Beamshape and Position" enabled on the Master Playback. This means rather than these attributes using the cue fade times, they will be instead scaled by the fader's position. To disable "Fader Controls", hold SETUP tap the Master Playback's GO button. Then, tap and disable "Colour", Beamshape" and "Position", so that they have a blue stripe next to them, rather than red. As a separate note, I noticed from your show file you are running out of date software. Keep an eye on our website over the next week, as we will be releasing software version ZerOS 7.9.4, that I would recommend you installing on your FLX S, as it will bring new features and enhancements. Hope that helps, any queries let me know. Edward
  9. Hi Daniel, Yes Derek is correct, copy the unzipped .exe to the root of a USB stick, plug into the FLX S, and tap SETUP -> Load File, and load in the file. The software update will begin. The process you describe is the old way of performing software updates. Hope that helps, any queries let me know. Edward
  10. Touch screen monitor
    Hi Jim, If your FLX S is displaying Press ENTER to complete calibration or Press ENTER to cancel calibration, then you are running out of date software. The latest release software is ZerOS 7.9.3, available to download and install here... Once you’ve got this installed, you should find this solves your issue. Edward
  11. ML Position move time
    Hi James, If your Fixture has a Postion speed parameter, usually this when set to 0% should mean full speed. Therefore your second cue should display a fade time, that you can use to define the duration from your first position to the second. Feel free to attach your show file and I’ll take a look. Edward
  12. additional dmx out
    Hi Simon, Ideally it needs to be on its own dedicated network. As a side note, FLX shouldn't be connected to the Internet. Edward
  13. additional dmx out
    Hi Simon, Yes this can be connected to a laptop, to allow your PC to become a standalone lighting controller. To do so you would need to be running PhantomZerOS on the laptop, with a Phantom Unlock dongle... http://zero88.com/products/consoles/index.shtml#scd http://zero88.com/forum/files/file/1-zeros-793/ Hope that helps, any queries let me know Edward
  14. Triggering cues problem
    Hi Stefan, Looking at your show file, Playback 71 has got Trigger on Raise Disabled. This means that remotely triggering this Playback from a cue is also disabled, which is why it isn't triggering from cue 82 of the Master Playback. You can change this setting by holding SETUP + tap Playback 71's button -> Raise & Lower -> Trigger on Raise -> Enabled. Chases set to one shot will run through the cues of the chase once, and then stop on the last step. Hope that helps, any queries let me know. Edward
  15. additional dmx out
    Hi Simon, Yes it is, with the use of a DMX Ethernet Gateway, such as our 1 Universe Ethernet box... http://zero88.com/products/control/ethernetbox/index.shtml You would then output sACN or Art-Net Ethernet protocols from the FLX into a Gateway to give you additional universes. Hope that helps Edward
  16. No output from cues!
    Hi Jim, There is no way of removing programmer time from the last encoder wheel in the Z key. By default this is disabled, and if you do tap it’s middle button to enable it, it will be set to 5 seconds. Did you manually release/ turn off your Playback? This is done by pressing and holding CLEAR, and tapping the Playback’s button. You would then need to take the Playback’s fader down, and then back up to see any light output. If it happens again, feel free to send me your show file and I’ll take a look at what may be causing it. Edward
  17. Color bumb & Intensity
    Hi John, Glad you like FLX S24! When you program a colour chase, the fades you see for that Playback’s Cues in the Cues window are for if you were to revert that chase back to a normal cue list. Therefore to edit chase settings such as the cross fade hold SETUP, and tap your chase’s Playback button. You will be able to see it is set to cross fade, and that the Colour crossfade percentage is set to 100%. You can tap this, and type/ use the encoder wheel to set the fade to 0%. Tap OK, and OK on the settings, and you’ll see your chase will snap the colours. Programming parameters without intensity is an advanced programming method. Therefore to do this, press and hold RECORD, and you’ll see the Record Options pops up on screen. In here you’ll see there is a button called SmartTag. By default this is enabled, however if you tap this, it will have a blue stripe next to it, meaning it is now disabled, allowing you to record parameters with 0% intensity. This does now mean that playbacks you record will only store “programmer” data, and not data from other playbacks. Programmer data is reperesented by red values in the output window, and parameters with a blue background. Tap RECORD again to close the record window, and now you can turn your fixtures on and setup their movement effect (such as a circle), then tap the Z Key, and tap the middle encoder button of the intensity wheel to Untag intensity. Tap RECORD, then tap the playback you want to store to, and your lighting will be stored, minus intensity. Hope that helps and makes sense, any queries let me know. Edward
  18. Edit fixtures on 7.9.3
    Hello, Yes the Frog colour scheme was removed, so that all consoles are now running the same scheme. Edward
  19. No output from cues!
    Hi Jimbo, That sounds odd. Did you set up a Playback to be a Grand Master and choose blackout accidentally? Did you apply a Programmer Time? Programmer Time is set on the last encoder wheel in the Z key Settings, and if enabled and turned to full will take 11 minutes 30 seconds for the programmer to be clearer. Could this be what you did? Edward
  20. Z Remote on iOS11 is not displayed correctly
    Hi Tapani, This is a known issue on FLX S consoles, and is due to be fixed in the next release of ZerOS, coming within the next few weeks. If you turn your iPhone landscape, and then connect to the console, you should find it displays correctly. Any queries let me know. Edward
  21. Flx48s. Playback window
    Hi Jim, If you tap SETUP -> System Settings -> External Monitor -> Disabled, this will bring these icons into the internal screen. Alternatively, updating your FLX S48 to ZerOS 7.9.3 will also bring those icons into the internal screen, along with bringing more new features and enhancements to the console. ZerOS 7.9.3 can be downloaded here... http://zero88.com/forum/files/file/1-zeros-793/ Hope that helps, any queries let me know. Edward
  22. Smart tag
    Hi Kevin, Yes that is a workaround if you wish to program fixtures without intensity with SmartTag. Just add in a Virtual Intensity channel to your Gobo rotator with no parameters scaled by it, and then on the console default the intensity to full. Edward
  23. fixture New Light M-Y8280
    Hello, Please find attached the updated fixture file... NEW LIGHT MY8280 Z88edit.ift The main issue seemed to be the RESET channel was defaulted to 255, which meant the fixture was constantly being sent a reset command. Hope that helps, any queries let me know. Edward
  24. Intensity effects
    Hello, Sorry to hear you struggled with the Effects Engine on FLX. In ZerOS 7.9.5, we're moving over to a new fixture library, which will allow the Effects engine to take advantage of multi-section fixtures such as SunStrips. Edward
  25. Go to cue x
    Hello, On Solution consoles to jump to a cue, ensure you are viewing the Memories Window, with the blue highlighted cell over any cue number. Then tap ENTER, use the MFKs to type the cue number you want to go to, tap ENTER, and tap GO. Hope that helps, any queries let me know. Edward
