mattyiench
2,094 profile views
mattyiench's Achievements
  1. Hi, There're no difference bye downgrade to 7.9.3. So, what've noticed: Some fixtures stop flicking by disabled RigSync! (This issue is resolved:-)). But i still have got some hazard flashing sessions, some or all of the led unit flash one time. Sometime i've to wait 1h to see that, sometime less. And the the flashs start to make a kind of a circle, a flash every 10min, or 20min. The light system is fine because it works really fine one month ago and it was the same! I've 2 univers, a splitter on each, N°1 for conventional, N°2 for LED. Every led power are on a separated wire, each family fixture has his separated dmx cable. I've check the power wire and i've already change it to another plug power. It 's not a electrical problem! or a wire issue. I've inverse the splitter to see also if it was a splitter issue... I've noticed something really weird with the Grand master; i've switch on the desk with grand master at zero, i didn't see it was at zero actually but all the faders works fine with it at zero. the black out button was not flashing red..to make the grand master works i've to up and down it.. That's not normal? You ok with that?;-( So I've call the dealer of my FLX in France, Axente in Paris, I'll sent it to them; Is it possible that the grd master is out of order and put some bad signal in the output of the desk? Cheers
  2. Hi, I'm going to downgrade 7.9.3, problems are still there, less flashes but it is still unstable. I've un-active RigSync, but nothing really change. I hope i'll be fine by downgrade. I'll let youknow Matt.
  3. Thanks Edward for having a look on the show, i did not send you the good one, you're right no head movers where patched actually, but this one has flickering issues. i did not check the output view when i had the issue with the Pointe. I will try this tomorrow morning, by unactivate RigSync first. I'm going to use Robe pointe also, i'll let you if strange things appear again:-) Regards. Matt.
  4. Hi Edward, Thanks for your answer! Actually, i've active Rigsync and I didn't try my desk without this on, i'll try it tomorrow. The fixtures who are randomly flickering are only LED unit... Some of those are old fixtures (all of them work fine with 7.9.2.5) I use: 12X LED chinese Bar RGBDS (i've made the fixture in the fixture tool) 4X Spotkolor RGBW from Starway 18X RGB LED panel 18X RGBW Smartbat + from Prolights And 24x Conventional fixtures The flickering is only visible on the LED units.. No problems with the conventional (;-) ) Yesterday I've try the desk with a Robe Pointe, the RIgSync works fine. But I've made some cues (dimmer and position cues) and things weird appears, like little bug... A position cue with 2 positions, with pan and tilt both, when clear the programmer, the 2nd cue only react on the the tilt..I clear the cue stack and it works fine... same things with a dimmer cue... i just put dimmer parameters in the programmer, record on a empty fader, after clearing, it doesn't work. All defaults parameters in the desk were fine also.. After clearing severals times, i did the same way of recording and it works fine... Maybe i can try to re-install the software? You can find in attachement the last show i use;-) Thanks for your reactivity Cheers JAROUSSKY V4.isf
  5. Ok, thanks i've find it already. Do you know if it is complicated to downgrade or this is the same way to upgrade? Cheers.
  6. Hi, I need to downgrade to 7.9.2.5 or 7.9.3. Can someone can tell me how can i do? Since I've upgrade to 7.9.4, i've some issues that i don't understand: -dmx signal seems to be not stable, like if the desk loose for a mms the signal, fixtures flash many times without doing anything at anytime. -fader doesn't work properly, i've to clear them severals times before to make it works -some weird things in the setup appears... -load and reload show in the set up to make things stop flashing ... I need help, i've try many things, like reset the desk to factory default, clear everything, make a new show, clean the desk physically also... The desk is running a lot this month and i need to find quickly a solution.. Sorry for my english... Matt.
  7. Hi, I've got the same issue with the remote app and my flx, the app is going too slow and does'nt work properly;-). This issue start since I've updated the flx to 7.9.4. I've got the lastest version on my iphone and the ipad i use for it. What can i do to make it works fine? Thanks for your answer. Regards Matt
  8. Hi Kevin, Thank you for all your answers I know what i have to do now... upgrade to 7.9.1! I was a bit anxious to upgrade before but i think i don't have the choise now! I will check what you've tried! Cheers. Matt.
  9. Thanks for everything! I'll check as soon as possible! When i say "preset" that means "palette" actually. I often update color palette or group, the name editing before disappear😕 Regards
  10. Hi, I'm using the FLX desk on V7.8.5, I'm looking for some tips... -Is there a function "move" (preset or playback) hide somewhere? actually I'm using "copy" to do that with the playbacks but it's quite boring with presets... -When update or merge a preset, this one lose its name.. Is there a way to keep it without writing again after update? -Can you remind me the highlight function with UDK, i didn't find it yet on the forum.. I'm using the FLX for more than six months, it's a nice, easy and powerful desk, i will be glad to have all this tips;-) Sorry for my english. Matt.
