Kirkup_xp
About Kirkup_xp
  • Birthday 06/12/1985
26,038 profile views
Kirkup_xp's Achievements
  1. Hi Irisse, Unfortunately it's not possible to copy a state from one show file to another. The best I can suggest is copying the values to paper, and then re-setting those values. Sorry about that. Peter
  2. Hi Piero We've now resolved this issue. It turned out to be a small bug in the Compulite tool - they don't add a carriage return after the end of the ENDDATA in the ASCII file, which the file format requires. We've fixed these files for you, so you should be able to load them into ZerOS. In the next version of ZerOS, we will be tollerant of this requirement for the carriage return, so you won't see this problem. You should be aware that in the show files, the Compulite tool has added a 4 second delay time to almost every fade up time on the show file - this might have been in the original file, but it seems unlikely. You can see this in the text file: CUE 4.2 UP 4.0 , 4.0 DOWN 0.0 , 0.0 You may want to perform a find and replace on this file, to remove these delay times - you can do this in Notepad or any other text editor. FIND UP 4.0 , 4.0 REPLACE WITH UP 4.0 , 0.0 Hope this helps, Peter Compulite Files Converted.zip
  3. Hi Matt Can you send me a show file with your patch and some submasters that aren't updating correctly? This mechanism should be working fine. Also, how are you updating the palettes? Do you re-record and merge, or use the Update function? Thanks, Peter
  4. Hi archie, Unfortunately, there's no easy way to do this. What you could do is program a sub which overrides the values HTP (so pull all the values to full), but of course that's going to be quite bright compared to the normal chase. Hope this helps,
  5. Hi archie Unfortunately, the chase speed is fixed on the Jesters to work just on the range of the modifier... there's no hidden faster range. On our ZerOS consoles, you can go upto 600 beats per minute. Sorry about that, Peter
  6. Hi Piero There's a utility on the Compulite website to convert from Spark (or any 4D) showfiles into ASCII. This outputs with a file .cpl - if you rename this to .txt, you can import them into ZerOS. However, there appears to be a problem bringing those files into Version 7.4 of ZerOS - i've just tried the whole process here and it's giving me some errors, which we'll need to fix. I'll let you know once these are fixed, and we can export a show file for you. I've attached the converted ASCII files to this message, incase those are helpful to you (you can view them in Notepad or any text editor). Peter
  7. Hi Ferg We've looked into this and it's a small bug with ZerOS which worked in older versions of Capture. Capture changed their software to modify the behaviour when it saw that bug, in version 2.7, which stopped it being able to see the desk. We'll get the bug fixed in the next version of ZerOS, which is nearing completion. The bug reference is ZOS-4864. I hope this helps, Peter
  8. Hi Ferg, We're looking into this at the moment - I should have some more news for you later today. Sorry for the delay with this, Peter (null)
  9. Hi Matt Do you have SmartTag enabled? What fixtures are you using? Thanks,
  10. Hi there, You don't need a hardware upgrade to enable the ZerOS Remote app. What type of router do you have? D-Link have a large product range, so it's worth checking the exact model number. Most importantly, we need to know if this router is acting as a DHCP server. Is your iPhone connected to the router, and does it have an IP address allocated from that router? What are the IP addresses of the two devices? If you're using DHCP on both devices, and the DHCP server (router) is allocating sequential addresses, you should see something like 192.168.0.4 and 192.168.0.5 for the two devices. If you try connecting a PC to the same router, does the ZerOS Remote Monitor application allow you to connect to the console?
  11. Hi Dan The effects engine in ZerOS only applies to the first Red Green Blue segment in a fixture, at the moment. To get around this, I generally patch it as multiple fixtures (one for each segment) plus a base fixture. I hope this helps, Peter
  12. Hi cycy, Sorry for the delay with this. Please find attached the profiles for all 3 types. cycy.ift I hope this helps,
  13. Hi there cycy Do you have the user manuals for these fixtures? I've had a look online but can't seem to find a user manual for these. We need to know the layout of each channel for the fixtures, for example: 1- Red 2 - Green 3 - Blue If you have a copy of these, please post it here and i'll get the fixture profiles made for you. Peter
  14. Hi bvanenk, You can adjust the programmed speed of the chases individually, by selecting the submaster and pushing EDIT, then making the adjustment required. For live adjustment on the fly, all chases will be adjusted together. I hope this helps to clear it up, Peter
  15. Hi Jake As you can see above, we actually released Phantom Jester back in 2008. This is available for download from the support pages: http://zero88.com/support/index.php?/Knowledgebase/Article/View/381/32/phantom-jester---offline-editor-for-jester-range---version-31-win2k---win7 I hope this helps, Peter
